The beatgrid of certain songs keeps getting shifted even after manually adjusting them like the adjustment is not saved within the track metadata file. The beatgrid lock feature available in Serato helps fix that issue like a set and forget feature. That same feature must be available in djay Pro.
A post was merged into an existing topic: Add a Beatgrid, BPM and Hot Cue Lock to djay
Merged with existing topic: Add a Beatgrid, BPM and Hot Cue Lock to djay
