Hello!
After 3 months of trial, I decided to make Djay my new main DJ software, walking away from Serato Pro. The 49.99 euro deal for one year subscription is just the best deal you can get on a professional DJ software right now if you don’t have a hardware-unlock at hand.
I hate the 1-month subscription model so this is just perfect and very cheap.
I have used Rekordbox, Serato and Traktor in the past and software Y comes with at least one less feature the software X has but software X has this unique feature that software Y dosen’t have.
So it is a mixed bag, it is all about what matters to you personally.
What I really like about DJay
Automated Beatgrid and BPM detection
This blew me away, no software comes near to the accuracy of djay -
The Settings and midimapping
Changing the settings and dive into midimapping is so easy and straight forward. Big shoutout. -
Stems
Djay take it to another level, the stem feature is just the best I have ever used -
Auto Gain
The auto gain may not come as a important feature, but it is really solid and the software register gain very well. -
The layout
The main screen of Djay is just minimalistic perfect. You got everything you need, you are not bombarded with unessential options and the color scheme is really clement.
What I would like to improve with DJay
More options for Library
The information from your library is very static. You can’t change much, you can’t add a comment or add colors (color is big thing for me). Is it a track I don’t like and want to add a note, that has to a mental note. And why is not “labels” not a option in the tree? -
Better Record window
The Record button and function does what it is supposed to do, but since I don’t see any volume LED, I get paranoid if sound is recorded or not -
Export Playlist
I can export in CSV but it looks crap, thought I could change what columns could be in it, but seems that I couldn’t. (I’ve tried to export and open in Windows Excel and…isch :), would be better if I could just export it to a txt file -
Midi controllers don’t send information of their state
One thing that has bothered me a bit that I have only problem with djay is that the djay software don’t registrate what the current state is of my controller. Example: if the volume fader on 50% when I enter the software, it will registrate as 0% or 100% till I move it. This goes also with all buttons and knobs. Never had that problem with serato or Traktor. Since I’m not a techy guy with software coding, I will just make a remark about it without knowing how hard it might be to do. -
Midi mapping dosen’t add colors to pads
Doing your own midi changes to your RGB pads dosen’t add colors, it is unlighted so it is very had to know if you have something on those pads.
Final thoughts
I really like Djay, I see for what it is and more importantly I see what it can become.
All DJ software has it’s quirks but I see a feature rich future for djay and that is why I have chosen it to be my new DJ software going forward.
