Set Default Play BPM
Hi. Is it possible to set the starting BPM of a song? I am not talking about the actual BPM of a song that is calculated during analysis but the BPM that you can manually set the song to play at.
Some context, I have a number of songs between 110 and 130 BPM and I want them all to play at 120 to have better consistency. I know that I can set this manually for each song and then beat / phrase match, but it would be easier if the songs loads with the 120 straight away.
Thanks for your thoughts and feedback. Vince
Hi BigVince,
You can edit the set BPM Value of a track in the BPM Pop Up.
You can find more information in section 5.5 of the djay for iOS manual:
https://help.algoriddim.com/hc/en-us/articles/360031071611-User-Manual-for-djay-for-iOS
