Set End Cue Points via iOS!
Yes!
The feature I’ve been waiting for for years!
This is huge…thank you team, coding is a bitch! I get it.
Djay Pro iOS v3.1.1
great!
perhaps you could use the lower part of the waveform overview to display the start and end point arrow ? it would be easier to see no? :wink:
i meant all cue points are displayed on the top of the waveform, you could use the bottom of the waveform also no?
That sounds good.
I always felt that the colored Cue point were diamond and the start end Cue point be trainhles
