Set pre cue
Hello, i just got a Numark DJ2GO2 and it immeditely and it works fine with djaypro but im having trouble with the pre cue settings. I wanna be able to to de pre cueing and connect a speaker to the controller.
Hello Miguel, Are you using djay Pro on Mac or Windows? If your controller requires a driver please make sure to install the latest. Does the audio interface for DJ2GO2 show up when you connect it to your computer and does it show up in djay Pro as an audio device in settings?
