I have DJ Pro on the Mac and when I make a recording, the saved file bit rate is 128kbps (file info in iTunes). How do I make it 256?
in the djay Pro settings you can set the Recording Quality to either AAC or WAV (10,1 Mbit / min) in order to have a higher Recording quality.
128 is way too low. It should be at least 256 or 320.
Thanks for the quick reply. But I’ve already purchased an app (Audio Hijack) that allows me to record in Apple lossless.
