Been playing a bit more with loops recently. What I’m finding is that trying to set a manual loop using a Rane one, always locks it to a beat on the grid. I’ve turned that option of in the settings but it still does it?
An example of wanting to loop out of the grid restrictions is that not all vocals start on beat, so you either miss the beginning or end of a vocal.
Is this a recent or reoccurring issue that has been troubling you?
Additionally would you be able to share a screen recording of this issue in action so that we can get a better understanding of what we’re dealing with?
I noticed this a while back but never thought much of it however l just tested it now and it doesn’t appear to be a problem for me…I can loop mid beat or wherever l start the loop function…
I have tested this with a normal track as well as a acapella track and l can’t replicate the issue like in your video
Ok l did further testing and l too was able to replicate the issue, but only whilst the track was playing…
which is what you were doing in the video…
if l set the loop at any point of the track when it is stopped, l can get it to loop at that point…
Yes it works if the track isn’t playing, but some times to create a build up I want to loop whilst the track is playing, then reduce the loop count etc
Finally, use the "IN’ and “OUT” buttons to set the loop start and stop points anywhere on the grid without the loop snapping to the downbeat. (Pictured below)
Hi All, Just wanted to chime in here to let you know that you should now be able to set a loop manually as expected while the track is playing with the latest update to djay Pro AI for iOS (version 4.0). You’ll find the option for this in djay’s Settings under General > Cue Points & Loops > “Snap Loops to Beat Grid”. With this toggled off, you should then be able to set the loop as expected.
Please let us know if you run into any other issues with this! And thanks for your patience.
