MacBook Air 2024 M3 16GB
Sonoma 14.1.1
djay 5.1.6
Reloop Mixon 8 Pro
Hi guys - I’ve found the following issues when using djay
1- Neural mix volumes reset on track load - my neural mix volumes are mapped to the rotary knobs, it would be good if could we have a check box like there is for eq/fx reset on track load
2- Manual FX parameters are not saving on app exit
3- Crossover setting (in settings) is not saving on app exit
4- Option to show sampler and looper missing from the configure midi menu (show waveforms etc is there though)
5- No option to navigate between match/history/queue in configure midi menu
6- One of the tempo faders goes non responsive during a mix when playing two decks together in the mix using sync
7- When using auto gain the volume jumps if the gain is then adjusted to the exact volume of the gain knob which is quite jarring when playing live - it would be so much better if it behaved like the auto gain does in Serato or Im having to manually gain each track as I play
Thanks! Will
