Share MIDI Mapping between devices
Hi.
I have a midi mapping I have set up for my Reloop mixture pro on my Ipad. Is there a very easy way to move this to my new Iphone?
Hi @Nubium, the easiest way is using the Files App and iCloud Drive.
  1. Open the Files App on your iPad.
  2. Navigate to On My iPad>djay and locate your custom MIDI mapping.
  3. Long press on the mapping file until the menu pops up.
  4. Select Move at the top middle.
  5. Then navigate to iCloud Drive and choose a folder to copy it to.
  6. Select the blue Copy button at the top right once you’re in the desired folder.
  7. Now open the Files App on your iPhone.
  8. Navigate to the iCloud Drive folder from above.
  9. Select your MIDI Mapping file and Move it to the djay folder on your iPhone.
Fantastic, u da man , this is why I love this app, cos YOU help sooooo much
It’s actually a little bit easier than that. All I had to do on my phone was open the midi mapping file and it automatically opened up djay And he asked me if I wanted to install that mapping.
You’re welcome @Nubium! Happy to help as usual. Thanks for the positive feedback - always appreciated :smiley:
