Share session history with multiple DJs
I work at many all-night and weekender events where there are multiple DJs playing at different times. One of the complaints from the attendees is that they often hear the same tracks played multiple times by different DJs.
What would be great is if all the DJs could join a “group history” that captures the track title/artist, the DJs name, and when it was played. If it could work cross platform, and maybe integrate with other DJ software, that would be awesome too!
If previously played songs could be flagged in the library, that would be amazing - kinda like they are already with a tick for the current session. But perhaps the tick could be one colour for “played by you” and another colour for “played by someone else”.
  1. You can share Apple Music playlists across platforms by making the playlist visible to friends and followers, or, share it directly through Email, Messenger, Airdrop etc.
  2. djay Pro (macOS) has a command to Export playlist to Music App …. The main limitation - this only works for DJ Set History.
Yes, I know that you can share playlists - that’s not what I was suggesting!
I’m asking for an easy way for multiple DJs to collaborate at an event to avoid playing the same tracks at that event.
Thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration.
