There are quite a few changes that I made in order to suit my djing style…
I’ll to try remember them all,
On Decks 1 & 2,
Cue 5 isolates Vocals
Cue 6 isolates Harmony
Cue 7 isolates Drums
Shift + High Eq Fades the Vocals
Shift + Mid Eq Fades the Harmony
Shift + Low Eq Fades the Drums
Shift +Filter activates Pan on each channel
Shift + Tap Starts/Stops Recording
Shift + Scroll skips through the track like Search/Scrub
Shift + Parameter Sets the Grid Start
Shift + Booth controls the Volume of the Looper
Shift + Depth controls the Volume of the Sampler
Shift + Pitch Bend on Deck 1 Changes the View Modes ie 2 deck mode - 4 deck mode - Looper mode etc,
Shift + Pitch Bend on Deck 2 Changes the Music Source modes ie ITunes , Tidal, Beat Source, SoundCloud, Files etc…
Saved Loops 1-8 activates instant FX 1-8
When in 4 Deck Mode,
Mic 1 Volume Level controls the Volume of Deck 3
Mic 1 High Eq controllers the Hi Eq of Deck 3
Mic 1 Low Eq controllers the Low Eq of Deck 3
Mic 2 Volume Level controls the Volume of Deck 4
Mic 2 High Eq controllers the Hi Eq of Deck 4
Mic 2 Low Eq controllers the Low Eq of Deck 4
Deck 1 Hot Cue 2nd menu (Yellow)
Cue 1 Play Pause Deck 3
Cue 2 is Deck 3 Cue 1
Cue 3 is Deck 3 Cue 2
Cue 4 is Deck 3 Cue 3
Deck 2 Hot Cue 2nd menu (Yellow)
Cue 1 Play Pause Deck 4
Cue 2 is Deck 4 Cue 1
Cue 3 is Deck 4 Cue 2
Cue 4 is Deck 4 Cue 3
Note that the Mic 1 & 2 Volume and Eq still work as normal…
