Hey all,
I use DJay Pro for Mac on my Reloop Beatpad controller. It used to be so that whenever you wanted to use “shift” button + “whatever”, you would have to hold the “shift” button and press on whatever button to work the secondary function of the button you wanted. But ever since one of the updates made it so that once you press shift button it would lock the shift so you don’t have to hold it anymore…
Since I got used to holding the shift button from original setting, now it messed me up once in a while where I forget the shift button is on and whenever I press a “cue” for instance, it would erase because “Shift” + “cue” is a setting for erasing the cue…
I was wondering if anyone knew how to “unlock” the shift button or knew a way to disable this feature?
