Shortcut for iPad and macOS.
Could you please tell me. Does the iPad version of Djay Pro 5 have the same amount of shortcuts as the macOS version?
Because the Windows version has a limited number of shortcuts.
Hi @Zirrex, the keyboard shortcuts on iOS are different than on macOS. A list of iOS shortcuts can be seen by holding the Command key.
Thank you so much for your reply! I really appreciate it. Could you possibly let me know if there is a limited number of options for MIDI mapping for iOS (iPad) as well, or is it as extensive as it is for macOS?
You’re welcome @Zirrex. As far as I know, the MIDI Mapping options are the same on iOS and macOS. I use my custom MIDI Mappings on both OS’s and have never had any issues with missing functions.
Would like to ask if i can map my shortcuts on iphone with an external keyboard connected via Bluetooth have been trying to use the cmd f for search its not working how can i get over it please
Hi @Brown_bkp, I’ve merged your topic with this existing one. Please see above. You cannot customize the shortcuts on iOS, but you can see what the mappings are by holding down the Command key.
