I think it would be great if there was a setting on the sample pads to have them be chocked by either by linking two(or more) pads so that hitting one will choke the other, a la a true drum pad where you can have the closed hi hat sound choke the ringing of an open hi hat sound.
If this can’t be done, at least have an option where a second tap on the pad can either re-trigger the sample, as it is now, or choke the sample.
You guys are awesome, I love DJay2! Keep up the great work, best DJay app in the App Store!
