Show Hot Cue Names on Waveform
When you make a cue point or loop you can name it on the cue pad . Wouldn’t it be great if the name showed up in the WAVEFORM where you see the cues themselves :pray: then if you were watching the waveforms you would see the words like “vocal in” etc
Hi @Felix2, thanks for the suggestion! Good idea. I have forwarded this to the dev team for consideration. In the meantime, you can rename Saved Loops and their name will be displayed on the main waveform.
Can it be seen on windows too or just for Mac?
@Reuben_Williams this is currently only supported on iOS and macOS.
I’m not sure if I can continue in this post, but taking advantage of the images and suggestions, it’s possible that the name or text found at the CUE point will appear in the Waveform, as in the example in the image. Example;
Hi @MarcosAraujo, I’ve moved your comment to this existing topic. Please vote above. Thanks!
