Sidebar History reverse order
it would be great if there’s an option to change the Sidebar History to show played songs the same order as the regular History list in Djay and other dj apps we’re so accustomed to.
When reviewing your History live, it’s much easier to scroll through the list from top to bottom in the order tracks were played, instead of having to scroll from bottom to top.
Thanks for the suggestion @Donn! Good idea. I have forwarded this to the dev team for consideration. In the meantime, please use the blue Vote button at the top left of this page so we can gauge user demand for this feature. Thanks!
Hi @Donn, would pinning the history playlist here be an option? This way it would be sorted in ascending order.
Hi Slak_Jaw,
Thanks for the suggestion! The only thing is, I like using the Library tab in the side panel to view a secondary playlist—being able to see two playlists at the same time is really useful.
There’s actually one more way to view History: it’s the icon located above your playlists. That view also lets you see your history in chronological order.
TIP: I only recently started looking at my history throughout the night, and it’s been great for feedback.
Hello
I would love the song order to be reversed when adding multiple songs (drag and drop) from history to a playlist. It would also be handy to be able to reverse the song order in a playlist. thanks!
Johan
Thanks for the suggestion @Johan_Rosenberg1. I have forwarded this to the dev team for consideration.
When saving a history of songs, the playlist is backwards. The most recent song is #1 while the actual first song is shown as the last.
Hi @gizmo, thanks for the suggestion. I’ve merged it with this existing one as they seem closely related.
Hello everyone, I’ve merged 3 of these similar topics into one as they seem closely related. You may need to re-vote above. Thanks!
