hey there, I’ve been noticing that on the last updates of djay pro, the Sidechain FX which I use a lot, sometimes gets out of sync, it does not work as it is supposed to, I use it on MacOS and 1 month or more before, it worked pretty well. I’m a little bit annoyed because I have to play live soon. Please check the sidechain, the first two songs or so work well, then it gets weird. You can notice if it’s doing the right job if you put a kick drum loop on the beat. 4 on the floor let’s say, so the sidechain works lowering the volume at the 4 on the floor of the song being played.
Thanks in advance, I’m from Chile. If I made a mistake on my English, that’s why.
Hi @benjamin_Bocaz, when creating new topics, please do not forget to answer the questions in our template with specific details about your setup not just “iPad” or “Latest Version”. This helps all of our community moderators to provide the most effective support to users with the utmost efficiency.
Hardware Firmware Version:
Can you please try to capture a video of the issue, upload it to your Google Drive/Dropbox, enable sharing permissions, then share a link to the video here? Thanks!
