Does anyone have any ideas for a simple lighting installation that is compact, easy to transport and quick to set up?
Basically, it doesn’t have to be able to do much, just a certain synchronicity with the music would be great. I’m thinking of an installation that can simply be connected to an audio output. Is there such a thing? Maybe someone here has a good idea. Thanks already! ![]()
Chauvet Gigbar are decent compact and easy to set up.
I picked up a set of light bars o
n AliExpress and I’m impressed—they work great, were simple to set up, and didn’t break the bank. I’ve used them in bars, cafés, and private parties, and they’ve delivered fantastic results every time. Plus, they synchronize with music, which really amps up the vibe
Hi, I use JB Systems Partyset. It has build in microphone and a series of programs that react to sound. I also added a USB-Laser module and USB Mushroom Module These modules can also work on a USB adapter 5V 2A (included) Simple to use not too expensive nice for small party’s or use at home…
6 modules possible.
Can also be used via DMX or wireless DMX , if you want to go a bit further for controlling the lights.
For full DMX control you need a controller that has 34 channels !!!
Less channels can also be used, using 4ch , 7ch or 10ch DMX control…
Also M-DMX or wireless DMX input possible. (instead of using DMX cables…).
Thanks for the suggestions @Dysfunk_DJ, @illya_kroon and @Rodge.
Also, welcome to the Community @Rodge!
