Ah thanks for the quick reply, unfortunately that’s not what I’m looking for but appreciate the advice!
You’re welcome @paazel. If you want to use Algoriddim’s Fluid Beatgrid™ you will need to use djay or Neural Mix Pro - these beatgrids are currently not exportable for use in other software.
This image shows the adjustments I had to make to line up the post quantize file.
Attached is the NMP Post Quantised file. If you use NMP to check, no doubt it will all line up, but outside of NMP pro, not so much.
Additional question - does quantising happen per beat or bar or other?
Thanks @N_C, I’ve passed this onto engineering…
