Hi Algoriddim!
Longtime user of djay and big fan of your work in general!
Is there any way to lock the BPMs of the two decks to each other such that a simultaneous change in tempo can be made? If not, don’t you think that’s an important feature to add that wouldn’t necessarily be too difficult to add in terms of the implementation side of things?
Thanks a lot people!
