First off…LOVE the new update. It’s great.
Unfortunately, it broke my Siri Shortcuts on iOS. So I can no longer automix my favorite playlist from the widgets screen as before. Any way to bring this back in an upcoming update?
Thank you for getting in touch and thank you for pointing out how you used the Siri Automix command.
We currently are not supporting the command but pushed the topic internally.
Thanks for getting back to me.
Just to clarify, it was in the previous release, incorporated into the Automix settings page. Not something that I created on my own.
We will bring this feature back to djay on our next update.
That’s great. Thank you!!
Similar issue here. The Siri shortcuts I set up through Settings –> Siri & Search –> Suggested Shortcuts stopped working on all my devices (3 iPhones, 1 iPad) so it looks like a specific iOS 14 issue rather than a device-specific one. I tried force-restarting my iPhone, re-recording a voice command and adding a new one, to no avail.
Anyone else encountered that problem and found a solution?
Thanks, All, for your patience, and my apologies for the late reply. I just wanted to let you know that SIRI Shortcuts were added in djay Pro AI with the release of version 3.7.2. Please note, however, that the shortcuts for Automix will only work with iTunes/Music playlists previously played with djay’s Automix.
To get these working, please follow these steps:
And now you can use SIRI to play one of your iTunes/Music playlists with Automix! Let us know if you have any questions.
The reason why I need this fixed, because it’s annoying every time I open the app, I have to search playlist in automix every time if you leave it idle for 5 minutes or so. I wish when you open the app it remembers the playlist and what song you were listening to, but that’s another issue.
Hi @dotunmo, I have reopened the original topic and moved your post here. Can you please confirm Emily’s solution above works for you or not?
I saw this thread before…(if you looked at my post, there was a link that goes straight to this)
This doesn’t work anymore.
Thanks for confirming @dotunmo. I will pass this onto our engineering team on Monday for further review. Thanks.
Hi again @dotunmo, sorry for the delayed reply. I co formed with engineering that Siri Shortcuts are no longer supported. However, they are looking into other options to remember Automix playlists and the playlist progress between sessions.
The other options are actually better. So that’s good news.
Good to hear
