I tried to look everywhere for that but can’t find it…
Please, where is the skip function on the PC djay pro app ?
I looked at the cue section and I can’t find it !
Thanks a lot.
Maxence
Thanks a lot.
Maxence
Hi @Maxence_P, good catch! I looked everywhere and couldn’t find this either. It is supposed to be in the Cue Point dropdown menu. I have passed onto the engineering and dev teams so they can fix this in an upcoming release. In the meantime, you can use keyboard shortcuts or MIDI map it to a DJ controller.
Hi again @Maxence_P, okay I found it!
