Since Djay 2 it is possible to use the “Slip-mode”, that allows scratching without leaving the beatgrid. I just wanna know if it is possible to slip the Play/Pause button to create a short brake effect without leaving the beatgrid when starting it again.
If this was not understandable, I mean that the track is running in the background even if you press Play/Pause.
Thanks for your attention!
