Hello there,
I’m new to the party - coming from virtual DJ and not having a fitting controllor for this software yet. i am trying it to see if i should get an ipad and a fitting controller.
2 things i just can’t find:
how to put a deck temporarely into slip mode so i can scratch it but it “plays” (silently) further in the beatgrid while scratching a chuck of it like a snare-drum?
how to analyze a big library. i added my root directory (which contains ~40 sub-directories) to “my files” and i just can analyze each and every folder by hand. as my library is a dynamic thing (changes and moves) i will have to redo that for each and every directory so far - which is a no-no for me. is there a better way to just say: “hey, here’s the root directory - please scan it all”?
also the search does not work in the way i structured my library on the harddisk. if i chose the root directory and go to the search field it does not seem to search subdirectories which is usually convinient.
any help would be appreciated as i like the software a lot so far. great performance, clean, fun to use.
