- Device model 14” MacBook Pro m3 16gb ram
- Version of operating system sequoia 15.7.4
- Version of djay 5.6.2
- Hardware/controllers used ddj1000
- Hardware firmware version current
- Please consider sharing a short video or screenshots to help clarify your issue
A) SUMMARY OF ISSUE: initially loading or pre queuing a song from my ssd (internal or external) is delayed by a few seconds.
After initial delay the songs load fast but if I wait a few min, let the song play out then load another song there is a delay again.
almost like it’s waking up the ssd and once it’s active it’s fast. Then goes to sleep again. If that makes sense.
when I first open djay and load a song a pop up says the song is unavailable. I close the pop up and it’s available and loads.
I first noticed it when I moved my collection to a mini SD card in a flush mount card adapter on my Mac. I just assumed it was a limitation of having my collection mounted in a aftermarket adapter and delt with it. It was getting too annoying so I moved back to my external ssd but it’s doing it there too.
- Just wad a few min.
C) EXPECTED RESULTS:
- My external ssd used to load super fast always.
D) ACTUAL RESULTS:
- Always an initial delay after a few min. Wait.
Thanks for the details about your issue and setup @Ralfi711. Can you please share a short screen recording of this that I can forward to our engineering team for review? Thanks!
Hello, Resurrecting this post.
I upgraded to the newest IOS on mac (Tahoe 26.5) I thought the issue was resolved after update but here is more detail on the issue.
It seems the more time I am Djing and the more time DJpro is “Open” the likelyhood of this issue happening increases. When I first open DJay everything loads fast, all pre-cueing is fast and deck loading. Last night i played for about 4 hours and at the end of my set my pre cues were taking 20 seconds or more and deck loading as well, and continuing to get worse where i thought the program was frozen.
Again, This issue is for the “First” track I pre-cue or try and load, after the first initial slow load the tracks load fast after that if i keep loading them but after i wait a bit (Time until track ends,) it happens again.
Something funky is going on..
Thank you!!
Thanks for the follow up and additional info @Ralfi711
