Hello alltogether,
Generally is the work with your programm very good.
I have two things to make the work with algoriddim and I DJ Pro from Numark much better!
First: Please make a small library on Deskdisplay of IPad on I DJ Pro, Like its shown on the cover Box of I DJ Pro from Numark!!! For very fast loadind in Professional Shows where you don’t need any effect in this moment.
Second: Please make colored buttens for example 10% when the buttens are swich off on I DJ Pro, often it’s not enought to see only the active buttens with 100%.
For better manuel in the Dark!
Thank you very much!
I hope in the next updates you can realise this!!!
Best regards
Robin Mehnert
