I would like to point out a small text issue in the Songs Match feature that can be easily corrected. In the “Custom Match” option, the accompanying text currently reads: “Match finds songs that go well with what is currently playing.”
However, this is not entirely accurate for the “Custom” option, as it allows users to manually drag a track into the match section. Therefore, the track being matched is not necessarily the one currently playing.
I believe updating the wording would improve clarity for users. Thank you for considering this feedback, and I look forward to any updates on this.
- Device model MacBook Pro 2019
- Version of operating system Mac OS, Sanoma 14.6.1.
- Version of djay: 5.2.3
- (Hardware/controllers used: Reloop Mixon 8 Pro)
