Even smaller row-height
Hi @dinomaskot, I’m guessing you are referring to the Library row height for each song?
Thanks for the suggestion. I’ll send this to the dev team for consideration.
I do. When font size is set to smallest there is space for the row height to be even smaller…
Thanks for confirming @dinomaskot
I’d like to propose the ability to set even smaller row heights for songs, as well as the ability to adjust the row height for playlists in the tree. Similar to Rekordbox, Serato and Traktor.
I’ve used rekordbox, and having a huge number of playlists made it much easier to quickly browse or search them simply by seeing more playlists at once.
In DJay Pro, the margins are much larger; let’s say I can see 30 playlists at a time in rekordbox, while DJay Pro sees much less.
It would be nice if there were a setting to customize this to your preferences.
Here are examples:
Thanks for the suggestion @Damian_Zbroinski. I’ve merged it with this existing related topic. Please revote above. Thanks!
Still waiting
Thanks for checking in.
