Smart Playlist Builder
Smart DJ Playlist Builder
Start with any track. The builder handles the rest —
BPM, key, year, genre, and stream checks — all locked to rules.
Key Features:
  • Anchor Track Start – Choose a song, build from there
  • BPM & Key Matching – Lock BPM range (±2) and match Camelot key for harmonic blends
  • Year Filter Slider – Lock in your preferred release era (e.g. 2015–2025)
  • Genre Toggle – Pick R&B, Hip-Hop, or All Genres
  • No Artist Repeat – Toggle on or off to control artist spacing
  • Auto Blacklist Filter – Flag or exclude problem tracks (manual or smart)
  • Stream Limit Filter – Toggle on to set minimum plays (Spotify, YouTube, Apple Music)
Set Duration + Segment Mode:
  • Set Length Slider – Build sets from 30 minutes up to 8 hours
  • Segment Builder – Toggle on to build in 5-song blocks with approval before continuing, or off to build full set length in one go
  • Quick Mix Tickbox – Mark tracks as quick mixes to adjust total set time dynamically based on shorter play lengths
Dynamic Vibe Shifts:
  • Auto Prompts – Suggest tempo changes (half or double time) after a set duration
  • Genre/Date Flip – Mid-set switches to shift energy (e.g. newer to older, genre change)
Track Sources + Smart Suggestions:
  • Pulls from your local song library, TIDAL or Apple Music playlists
  • Includes trending and curated crates from DJ Pro
  • Highlights songs from pre-tagged folders or smart crates as priority suggestions in the playlist builder
Verified live via Tunebat for BPM and key Accuracy.
Export to CSV for client review (e.g. weddings, corporate events).
Hey @Owe_Marley !
This idea definitely has my attention and you’ve got my vote — honestly, who wouldn’t want something like this? It sounds amazing and would be a dream tool for DJs.
That said, we also have to be realistic: implementing something this advanced would probably require a huge amount of development resources. Especially considering there are already so many other suggestions on the table — smaller, step-by-step improvements, some of which are also focused on playlist and Match feature improvements.
Maybe this could be a great long-term vision, while we continue to push for more incremental updates in the meantime?
You got my vote too! this would be so great if it can be integrated to Djay!
Thanks for the suggestion @Owe_Marley. Good idea. I have forwarded this to the dev team for consideration.
