Smart Playlist/Filter logic for “OR”, “AND”
A simple suggestion: right now it appears you can only set smart playlist rules using AND logic. Please add OR option. like Genre “Rnb” OR comment containts “rnb”, if you enable both options now - nothing will be selected, cause it is only possible to apply all selected filters at once.
Hi @Akrilovy, you can already do this.
  1. If you want to use “OR”, select multiple Genres within a single rule.
  2. If you want to use “AND” make a separate rule for each Genre and turn them on at the same time.
I have changed your topic from a Suggestion to a Question. I hope that helps!
What about the situation which I want to select either genre “RnB” or files that contain comment “RnB” but market different style?
Currently, the “OR” command only works within a single rule not between multiple rules. I will pass on the suggestion to the dev team to have an “OR” command between multiple rules though.
I searched through the suggestion list but couldn’t find related topics–maybe im not using the correct keywords in my search. If duplicate topic please refer me to the link.
SUGGESTION:
Speaking from a database/technical POV… We need the smart playlist filters to be able to have an “or” operator between the input parameters in the filter statement not just “and” as the system is currently.
Put another way… we need a “match any” not a “match all”.
My use case for reference:
I am trying to create a smart playlist where:
–> Genre contains “scratch beats” OR Title contains “instrumental”
If there is a way to do this that I have missed, please let me know! Thank you!
Hi @Hosakilla, welcome to the Community! Thanks for the suggestion. I’ve merged yours with this existing one as they are closely related. You can re-vote at the top left of this page. Thanks!
