Smooth Echo Feature - Similar to Opus Quad
A Smooth Echo similar to what Pioneer has on the DJM-S11 and Opus Quad would be great.
  1. Basically this allows you to add an automatic Echo Out FX.
  2. Instead of selecting and engaging the Echo Out manually, you can choose how it is automatically activated.
  3. For example when closing the channel fader, moving the cross fader across, pressing a Hot Cue or when pausing the track.
See 6:33-8:20 in the linked video: https://www.youtube.com/watch?v=clUCDPz2Gs0
We need that feature…2nd!
This would be a great feature and easy to implement I am sure.
This was since also implemented on Engine DJ (Denon and Numark standalone DJ controllers) on December 23, branded “Fader Echo”
I think it should be implemented for any mixer. Will also help to match mappings between Djay and other software.
I’m in :slight_smile: Djay Pro AI give us this future!
voted
even the Prime G2 standalone does this now
I also have it as a HW effect on the Rane Performer
Thanks again @dj_estrela
