SOLVED:
I did a Beta Update in macOS Sequoia.
After couple of restarts and reinstall of RME driver i opened Djay and i could quickly switch to Beatport instead of Soundcloud.
No idea why but it works again…Maybe it was because i use VPN, maybe because of some driver issue, but my system got totally F’ed after using Soundcloud GO+ in Djay on mac. So i disconnected the Soundcloud account
Summary of the issue:
Hi guys, i cant use djay pro at all…iver tried reinstalling a couple of times. It crashes on opening. Seems to be waiting on Soundcloud (last opened browser window).
How can i delete all the prefs, and start fresh? It seems to copy my user account and settings on re-install.
How to reproduce the issue:
Link Sound Cloud Go+, open djay on macbook pro m2 max/sequoia
everythng latest updates
