HI - this may be “working as intended”, but in short, when using Djay for iPad controlling a Denon Prime 4, when using the eq knobs for Neural mix, the effects start, but the coinciding values do not change on-screen. You can use the sliders on the screen as well but when you change the knobs on the controller they dont move. I’m guessing at best this may be a design decision, as the filter knob coincides just fine. Can a dev pipe in and tell me if Im crazy here or if this is WAI?
Hi @aaron1138,
Thanks for sharing this inquiry with us!
So that I can better assist you, could you please answer the following questions:
- What iPad model are you using?
- What version of iOS are you running?
- What version of djay are you using?
- Is this issue still reproducible?
