Hi @ all and developping’s djay staff
I’m from Italy and I am a professional dj.
here is the extremely needs for a professional djing using idj pro
with djay for ipad.
I use for hours test’s consolle from numark and djay. After this
tests i report to U what it is good and what u must improve.
Good:
stability is very good, over six hours of set without problem!!!
bpm analyze is pretty good. like every other dj pro software
audio quality is good
to IMPROVE
auto gain ( it is better to insert two different range of auto gain es. -3 db- 0 db etc…)
more songs are different volume after analysys.
It is usable insert a knob for controll gain, instead touch gain on ipad, of every deck. it is possible to have it on fx knob of idjpro when fx is off it would works like a gain .
browser song list, quite good but not so clear to read in portrait mode . Also will be perfect if djay can save a hystory of a dj set, so dj could recharge speedly songs played in a last set.
FX are too high of volume, so will be perfect to have also for them a
little controll range of volume. I belive it is ok a little slider
volume on screen for touch controll
Autoloop, it is not so perfect… when u short loop from 4 beats to 2
to 1 sometimes the track jump… it is not good to listen…
Sampler, insert it! it is very very important…( i know is in program in next release)
I want to use my dj pro and my ipad djay for work in a club!!!
Insert this mod and u’ll have the perfect dj software for ipad !
Regards
Carletto dj
