Yesterday I upgraded my Djay Pro from V21 to V5.
Now some (most) of the tracks in my soundcloud playlists are showing as unavailable.
I had to upgrade to the later version as I am changing laptop and I have a gig this weekend where guests have sent me their playlists in advance so I am very keen to get this fixed.
Have you tried to Analyze Songs from the playlist dropdown menu to see if they change from grayed out? Perhaps djay is still reanalyzing your large SoundCloud library.
If I search for one of the greyed out songs in Djay, then the search function doesn’t find them.
(however if I search in soundcloud it finds and plays fine)
If I search for the artist I can find the song in the search panel, but its greyed out there too…
@Ben_Keeping are you logged into SoundCloud on both versions of djay using the same credentials (ie the same user account and password)? This feels to me like some kind of SoundCloud region restriction of the songs or something. Have you reached out to SoundCloud yet?
I’ve logged a call with soundcloud but haven’t heard back yet.
I found an article on a serato messageboard that if the creator of the track has disabled “playing with API” then that stops it playing in serato. Could it be the same thing here? (its not possible to see that setting on soundcloud to check)
Only question then would be why v1 can play the tracks but v5 not?
Hi @Ben_Keeping, I’m not sure what else to suggest here.
The API could indeed be the issue as this may have changed from v1 to v5.
Also, I can confirm that the support team received your request via the app so it has been logged there as well. However, we have recently launch djay Pro 5.0 for macOS and iOS so please understand that it make take some longer than expected to investigate this further. Sorry.
Hopefully you get a response from SoundCloud soon. If they are able to solve this, please share your findings here in case other users experience the same problem. Thanks!
