Reloop Buddy, iPad Pro, Tidal, full subscriptions to everything but some songs are only partially loading.
Restarted iPad, uninstalled Djay app, reinstalled, can’t figure out why some songs don’t load completely.
Hi @WhenIFeelLikeIt, please try changing your streaming quality setting to Normal to see if that helps.
That’s the fix! Thank you.
I have also noticed this before, but also that it is only displayed in this way, but the tracks are still complete and playable. But that could also have been a coincidence. Either way, this is of course a problem that should be fixed. Changing the sound quality, especially downwards, should not be the permanent solution here.
