Song Analysis slower on latest MacBook Air than iOS
Hello,
Not really a bug, and not even something annoying, but probably something to check.
I have an Apple iPhone 17 (2025), an iPad Pro M4 (2025) and a MacBook Air M5 (2026).
All my Software (IOS, MacOs, Djay are up to date : IOS/MacOs 27.2 and Djay 5.10.
The song analysis is lightning fast on both IOS devices above.
But comparatively much slower on MacBook Air M5 of this year (2026), which is the newest of all.
There are two versions of this MacBook Air - Mine is the strongest one : 10 CPU/10GPU/24Gb RAM.
Not really a problem, but a bit weird.
So, my sole intention here is to report this so that the Dev Team can check whether this isn’t a symptom of a deeper thing. And if not, no problem.
PS : I did the analysis on the MacBook first, but if I understand correctly, song analysis data are not stored in the cloud, so this shouldn’t have an influence. Correct ?
Hi again @Davidv100, thanks for the detailed report. Regarding the cloud question, you’re right. iCloud sync in djay only carries cue points and loop regions. BPM analysis data isn’t synced, so each device analyzes its own copy of the track. Analyzing on the MacBook first wouldn’t have affected how fast iOS did it.
Our docs don’t explain why the Mac would be slower, so I’d like to narrow it down before passing it on. A few quick questions:
  1. Where are the tracks coming from on each device: local files, Apple Music, TIDAL, Beatport/Beatsource? Are they the same tracks on both?
  2. If you’re using a streaming service, do you have the same streaming quality settings on all devices?
  3. On the Mac, are the files on the internal drive or an external drive?
  4. Roughly how long does one track take on each device? Are you batch analyzing (Analyze Songs from the drop-down next to the track counter) or loading tracks to a deck?
  5. I’m guessing your djay version is 5.6.10 not 5.10.
In the meantime, batch analyzing while the Mac is idle (overnight works well) means tracks are ready to go when you load them. I hope that helps!
Hi @Slak_Jaw ,
Yes, sorry, I should have added this info indeed :
  • All tracks are from Apple Music Streaming - and are not local. The same is true for all three devices.
  • On IOS, Analysis is incredibly fast. Much less than a second per track.
  • On MacOS, I’d say, like 5 seconds per track which is already fast. So, as I said, it is very acceptable and not even annoying, the question is more about “why the difference ?”.
  • It were the same 117 tracks on all three devices (preparing an event for upcoming Saturday - fall back scenario).
  • IOS devices were on WIFI (60 Mbps - old router - just tested), whereas the Macbook was directly on Ethernet (200 Mbps wired connection - just tested), all at my home, the same day, the same hour, same spot in my house. So, this is another reason why the Macbook should have been faster.
  • So, all “same” streaming quality - all using same Apple Music account. Once at the time (as Apple wouldn’t have allowed concurrent use anyway, I guess).
    Yes, batch analysing : the whole reference playlist at once (117 songs).
  • Yes, ofc - Djay 5.6.10. Sorry, always looking forward :sweat_smile:
About analyzing on Mac at night - No need, I am not complaining at all - This is not a nuisance - this reporting is not exactly about a bug. It is not a problem for me at all. It is more of an attention point to the Dev Team (something worth checking - possible deeper issue - or not).
I mean, IOS more than 5X or even 10x faster than MacOS…
While the Mac is the newest device and the one wired-connected (200 Mbps vs 60 Mbps).
One explanation could be that Djay analysis on MacOS is more accurate - or goes more into detail - idk.
@Davidv100 thanks, that’s a really clean comparison. That probably explains why the M5 and the wired connection don’t help on the Mac. djay analyzes Apple Music tracks one at a time, and when that change came in (djay 5.1.3) the team said there are imposed limits on how fast Apple Music playlists can be analyzed. For Apple Music, the speed isn’t really decided by CPU or bandwidth.
It doesn’t explain why iOS gets through the same playlist so much faster, though. Nothing in our docs describes a platform difference here, and I can’t confirm that the Mac analysis goes into more detail. I’ll pass your numbers on to the team.
If you’re curious and have five minutes, one test would really help narrow it down. Batch analyze the same 5–10 local files (not Apple Music) on the Mac and on the iPad Pro. If the gap goes away, it points at the Apple Music side. If it stays, it points at the analysis itself. Before you start, check that Settings > Library > BPM Analysis > Tempo Change Detection is set the same on both.
Again, not a real issue for me. Even on MacOS, analysis is fast enough for me.
I won’t run a test on local music, tho, I am fully using Apple Music, and don’t even remember where I store local music - I am only using local files (2 or 3 songs) for Stems. I like Stems a lot, and would like to use it more, when Apple allows it. Not a money issue, it is more about convenience (and cloud syncing).
Though, I will check whether I have the same settings for Analysis (“Tempo Change Detection” your are mentioning) on all devices (IOS analysis is so fast that I am thinking I am probably not using the same settings indeed.
@Davidv100 sounds good. No worries at all about the local-file test. Checking the settings is a good next step. Whatever you find with Settings > Library > BPM Analysis > Tempo Change Detection on each device, post it back here and I’ll add it to what I pass on to the team.
Hi @Slak_Jaw ,
So, I did a little bit of further checking and testing.
  • All my settings regarding Djay Analysis on all three devices Mac M5, iPad Pro M4, iPhone 17 are the same. (the standard Djay settings, untouched).
  • All my music tracks are Hi-Res (max resolution) on all devices.
  • The situation is the same in both batch analysis (whole playlist) or single song analysis. In both cases, the same time difference exists (I mean, the time per track is the same in both individual and batch analysis). With the x5 to x10 difference between MacOS and IOS unchanged (still the same “issue”).
  • I even downloaded the tracks (not buying but downloading on Apple Music on the Mac) to check for any improvement, but no. Doesn’t change anything.
I still have this x5 or even x10 Analysis time difference (much slower on Mac - like 5 seconds instead of 1).
Again, this is not a nuisance.
But might be worth checking by the Dev Team, imho. The question is “why ?”.
I mean, what I am thinking about, is that if this has some deeper root cause, this issue might also exist in Stems, or everything “deep digital analysis”.
The Analysis time difference in itself is not an issue (I mean, 5-8 seconds per track is still more than fast enough for me).
Hi again @Davidv100, thanks for the additional testing and info. Same default settings everywhere, the same gap for single and batch analysis, and no change with downloads: that rules out everything on your side. I’m passing it to the dev team now with all your numbers.
Downloading didn’t help because djay’s Apple Music source doesn’t use tracks downloaded in the Apple Music app. It always streams them. I’ll post back here once I hear something. Thanks!
