Song duration and crossfade
YOUR QUESTION:
  1. I’m a keen rollerskater and I usually skate in groups and use Spotify for our music played via Bluetooth speaker. My question is can djay pro reduce the song duration say for just two minutes and use crossfade to load the next song. Spotify does have a crossfade function but it’s only for 12 seconds. In a nutshell I want to be able to create a mixtape of our playlist without doing anything apart from pressing play. Thanks
Hi @Dee_Jay1, welcome to the Community! Yes, with Automix, you set both the song duration (“Maximum song play duration”) and the crossfade (“Mix-Transition”, “Mix-Duration”). Please refer to the Automix section of the djay manual linked below for more details on the various settings.
Just let me know if you have any additional questions after reviewing this info and I’ll be happy to help further…
Thank you so much for the detailed explanation. Sorry last question (I hope hehe). The functionality you mentioned, are they available on the mobile phone app too, I’m currently using Android. In terms of the Automix, do I need to load two different playlist or is one ok and I just tweak the Automix and Crossfade settings?
You’re welcome @Dee_Jay1. Yes, this functionality is available on Android mobile. You can load a single playlist and adjust the Automix and crossfade settings as shared in the Automix settings help topic above.
