Hi, do I need to use iTunes with djay app or can I use an alternative? If somehow do you do this and what are the options?
Hi Matthew,
djay directly integrates the iPad’s music library (=“iTunes library”). To load music from other apps, you have the following options:
- Audio Copy & Paste
- Open In…
Please note that the other app needs to support the respective feature as well.
Hi Warren,
You said that you can use other apps with Djay Algoriddim.
Am I able to use Djay Algoriddim to play music from my G-Connect 500 hard drive?
