Song loading for RESET TEMPO not saving after DJpro
Restart of program.
Hello @elsandesh ,
Thanks for posting in the Algoriddim Community and welcome!
Could you please provide the following information:
- Which device do you have?
- Which OS version is running on your device?
- Which djay version are you using? (If you are using an iOS/ Android device, please open the djay settings and scroll down to determine the version number.)
- Please explain step-by-step the issue you are experiencing with djay, what you expect to happen, and what actually happens.
Thanks in advance for the additional information! I look forward to hearing from you
