I’ve emailed support 48 hrs ago but have not received a response yet. Can anyone confirm that the trial version of Djay Pro 2 for Mac does not have the ‘song match’ feature activated? And is only available after full purchase? Cheers
I don’t see it either.
The UI needs more work it seems. I would never have guessed to choose the option you mention.
Ok, disregard, found it.
Not user friendly, I was sure I had gone through every single part of this app over two days…
Under ‘View’ you need to have ‘Show Library Inspector’ ticked in order for the match features to display on the bottom right with the little CD type icon.
