With the end of Spotify support in Djay Pro, I recently switch to using only Music App (formerly iTunes) as my songs source.
I make extensive use of various tags for my songs in Music App: Star Rating, Genre, Year, Comments, …
While all the tags are properly populated for all my songs in the “Music” (aka Apple Music App) tab, I noticed that the tags are empty for a significant portion of the songs referenced in “My Library” tab.
See the screenshot attached as an example:
The bottom tab shows the content of a playlist in Music App called “$Latino” which contains 59 songs.
The top tab shows the content a playlist in “My Library” called “Copy of Latino Playlist” with the same 59 songs.
As you can see in the bottom tab, the 16 songs from "Rapunzel"down to “We are One” have rating and year, some have Genre, and comments, …
However, for the same 16 songs in the top tab, 9 songs do not have any information populated for Rating, Genre, Year, and Comments:
Samba de Janeiro, Sexual Healing, Suavemente, …
I have tried to update some of the fields of the affected songs from the Music app just in case, but it does not fix the issue.
Can you fix this issue?
Let me know if you need more information to help troubleshooting.
MacOS 10.15.6
Djay Pro 2.2.5
Music 1.0.6.10
