This started happening after the new djay2 update. When I start recording, the right deck keeps playing. The only way it stops is if I load new song but that throws my whole mix off. Is this an iOS problem or a djay2 app problem?
Hi Don,
Thanks for contacting us. Can you please provide more information regarding the problem?
- Which iOS version do you have?
- Which djay version are you using? Please tap the gear icon to determine the version number.
- What are the steps to reproduce the problem?
