I recently purchased a second MacBook Pro. I authorized the new laptop in iTunes and loaded my music into the library. I installed djay pro. Now none of the songs I purchased directly from iTunes show up on either computer in djay pro. They are downloaded to the hard drive and in iTunes and play fine from iTunes. I went into the iTunes preferences>advanced and clicked “Share iTunes Library XML with other applications”. All of the songs that I did not purchase from iTunes play fine in djay and show up. This problem is only happening with music purchased from iTunes.
Hi James,
thank you for your post. Is it possible that you use Apple Music to get your Music files?
No, these are songs I’ve purchased from iTunes.
