Device model : iPad Air 2024 M2
Version of operating system : iOS 17.7
Version of djay : 5.2.4
Hardware/controllers used : Reloop Mixtour Pro
Summary of the issue: I’ve got a particular Smart Playlist of 173 songs, and I’m using Numerical Key (1a/1B) format for my Key tag. Based on the good range of tracks I have in that list…
If I sort the playlist by Key Ascending I will see tracks in this order:
8B, 8A, 9B, 9A, 10A, 11A, 12A, 1A, 2A, 3B, 3A, 4B, 4A, 5B, 5A, 6B, 6A, 7B, 7A
If I switch the sort to Key Descending I will see the reverse order:
7A, 7B, 6A, 6B, 5A, 5B, 4A, 4B, 3A, 3B, 2A, 1A, 12A, 12B, 11A, 10A, 9A, 9B, 8A, 8B
How to reproduce the issue: The issue is common across all playlist/library listings.
It’s really off-putting, given that the Key tag is written there by Djay during its analysis it’s not possible (nor would I want to!) mess about with the tags. It should be in numerical and the alphabetical order. (And no comments please about using “0” to make (0)1A come first, nothing else does it that way!)
Sort by Key Ascending should be in this example:
1A, 1B, 2A, 3A, 3B, 4A, 4B, 5A, 5B, 6A, 6B, 7A, 7B, 8A, 8B, 9A, 9B, 10A, 11A, 12A
Sort by Key Descending should be in this example:
12A, 11A, 10A, 9B, 9A, 8B, 8A, 7B, 7A, 6B, 6A, 5B, 5A, 4B, 4A, 3B, 3A, 2A, 1B, 1A
Thanks very much.
Kind regards,
James
