Sorting by BPM & Key together
Hi, would it be possible to get an update to sort crates by BPM & Key together. It would make more sense when scrolling through my lists.
Thank you!
@Rob_Peach_Mellor you can kind of do this within the My Library Playlists. You can sort the playlist by BPM first the apply a secondary filter. Unfortunately, this will only allow you to select a specific key to filter.
Hi @Rob_Peach_Mellor,
As @Slak_Jaw mentioned, you are able to achieve that sorting method through your “My Library”. Additionally, they are correct in saying you will only be able to then select a specific key.
Thank you @Slak_Jaw for the screenshots and information!
