Sorting music by multiple columns(parameters)
Would be nice to be able to sort the music by multiple columns:
f.e. - BPM + KEY; BPM + KEY + Date added; Date added + genre etc.
for me I’m using custom field as my primary as a bypass since bpm+key cannot be selected at the same time currently, but still this functionality would be nice. I couldn’t remember if I suggested this before or not, sorry
Hi @Akrilovy,
Thanks for sharing your suggestion!
I’ve gone ahead and shared it with the team for further consideration.
Appreciate it!
Yes really need to copy Rekordbox here. The user can choose what colums are important. For example I have # (order of songs that I can re-arrange), then title, then artist, then BPM, then KEY, then time, then my Star rating. And if I scroll, I can see album, comments, and more info such a “color” rating, date added etc times played. Very easy to search for something when you have that data at your fingertips. Library management in Algoriddm is severely lacking unfortunately!
FYI This was suggested here as well.
Hey, could we add a Sort by BPM, Key, and more sorting options? I know we have filters, but it would be much better if we could click to sort by BPM, Key, Genre, Color, Year, etc. Serato offers this but only allows sorting by two (BPM and Key). Right now, my filters are set up, but they take up too much screen space.
Hi @Owe_Marley, thanks for the suggestion, however, please use search before creating new topics. I have merged your new topic with this existing one. You can vote for this suggestion at the top left of the page. Thanks.
Macbook M4 Pro/MacOS Sequoia 15.4.1/Djay Pro 5.3/Rane Performer
I’ve been looking through the manual and the forum and haven’t found the answer: is it possible to sort a playlist by two criteria at once, for example by musical key and by BPM, like you can do in Serato? Thanks in advance.
Hi @DjLemart, please use search before creating new topics. I have merged your new topic with this existing one.
In case you are not familiar with the feature, djay does have the ability to use multiple Filters on a playlist.
Also, here’s another related topic specifically to BPM + Key sorting: Secondary Column Sorting - Bpm & Key - #10 by SpinThis
Hi, thanks for the suggestion but that wasn’t what I was asking for… I know I can filter by BMP and then to add another filter for a certain key, but that’s not the point: In Serato, if you order by BMP and you press COMMAND+click on a second row (i.e. Key), it shorts the playlist in that order, not just a single Key as the filter.
Regards,
DJ Lemart
You’re welcome @DjLemart. Understood. In that case, please use the blue Vote button at the top left of this page or in the other topic that I linked above. Thanks!
This is a workaround, that I’m using for a year now. I use a sorting by comment - where I put the key and BPM like this. Hope this is helpful
Brilliant, many thanks :folded_hands:
Any update on that feature? Would love to start sorting playlists and crates in a set order, and have the main library arranged by BPM and key.
Hi @Owe_Marley, we don’t have any news to share regarding this suggestion.
Would it be possible to add this when building sets? It’d really help to browse the main library with filters on while looking for the next track. At the moment it’s a bit of a process turning filters on, re-sorting playlists, then switching back again. Being able to stay in the main library, scroll with filters active, and drop tracks straight into playlists would make set building much smoother.
Thanks for the additional input @Owe_Marley. I’ll pass this onto the devs.
In the meantime, the following feature was added to djay 5.5 for macOS:
  • Added support for sorting the media library by two columns (hold Shift/Cmd when clicking the second header). MacOS only.
Amazing, i missed this reading release notes on last update and this has made my weekend, thank you
You’re welcome @Owe_Marley
Has this feature been added to Windows yet?
Hi @DJWillz, welcome to the Community! No this feature has not been added to Windows yet.
