Is there a way to make sure that the playlists I create in iTunes follow a special order? It seems the order is Radom. I even tried to get order with numbers, but that doesn’t change at all. I have booth smart and normal playlists. Thanks for all tips
Hi Claudio,
The order should be the same as in the Music app. Is this not the case?
There is no way to alter the sorting of playlists in djay, at the moment. As already mentioned, the sorting is the same as in the Music app.
Actually I mean the order that appears in the browser in Djay on the iPad.
I think it first sorts smart playlists alphabetically, then normal playlists alphabetically. I would rather prefer if all playlists would be sorted alphabetically. What do you think?
