I have made some set lists in Djay Pro Ai and I want all tracks to stay in the same order as I added them in the first place. As soon as I sort any other playlist for BPM or key, it changes my set lists as well, but how can I return to their original order. Djay Pro for iOS has a reset option for this but I can’t find anything similar in MacOS
If you click on the title of a column, it will cycle through 3 sorts: ascending, descending and original. Is that what you’re looking for?
I never noticed that it returns to the original. Thanks
