I’ve bought DJayPRO for Windows OS in Windows online store, but the app turned out to be not compatible with WeGO4 midi contoroller I was planning to use it with. How can i get a refund and get rid of that application?
It should work fine with the WEGO4 controller. Mine does. Are you using Windows 10?
